Hi;
Actually, this is not a problem, but there are 2 points that I avoid.
1) The buttons slide down quickly. How can we soften?
2) I turn off the footer, but it reopens automatically. I cannot turn off the footer on a single page.
Sample Page;
https://myblogtr.com/hizmetler
Best Regards – MYBLOGTR
Hello !
Once opened the tagdiv composer you can either edit the header or the footer by using the website manager: https://www.screencast.com/t/5VkiUmHQvF
You can import or add a different header for the homepage.
