So i had to do a single template for auto loader, how to enable smart sidebar
I can only place a non-scrolling one, please help.
Also it sometimes doesnt load the next post when i scroll down.
You can make the column containing the sidebar sticky – http://prntscr.com/mhxpn2
The general setting in the theme panel has to be active – http://prntscr.com/mhxpxo
If you have a problem with the auto load feature, please post a link to the post where this is happening. Be sure to check the settings for it – http://prntscr.com/mhxqtv
Just any post really, check this for example:
https://nullfud.com/ripple-dips-after-coinbase-rejects-rumors-of-adding-new-assets/
it has loaded 1 extra article, last time it was 3 extra, it all changes randomly, the setting is set to auto loading type previous posts and auto loaded articles is set to 10
Also thank you that sticky thing worked, however when i scroll to the end of the post and the next post auto loads up under it, that post doesnt have the sticky option enabled so it just stays at the top, how to fix that?
So you have set it to show previous posts and a limit of 10 posts, from what I can see at the moment only on post is loaded.
Please send us an email at contact@tagdiv.com and provide admin login so we can take a look. Include a link to this topic in the email.
With the sticky sidebar there seems to be a problem indeed. I will pass this along to the developer team and they will fix it as soon as possible. Sorry for the inconvenience.
