Social counter and problem in instagram
I have version 9.2 of the Newspaper theme. The problem is that the instagram widget does not work anywhere. This error occurs:
Instagram data error: Instagram html data can not be retrieved
I have tried the provisional solution that you gave, changing the code of two files,one for the instagram widget and one for the social counter, and it has not worked, nor the counter of followers. I do not know what to do. I have tried everything.
help me.Thank you
I have placed the instagram widget in the footer, but it does not work if I put it somewhere else.My website is:
http://www.valdeorrasdecerca.com
The social counter does not work either.
Thank you
Should work in version 9.2. Seems to work when I test your ID – http://prntscr.com/msz5ev
Try to switch to a test ID like cocacola for example – http://prntscr.com/msz60n
See if that works, then switch to your own.
If the problem remains, send us an email at contact@tagdiv.com and provide admin login so we can take a look. Please include a link to this topic in the email.
Delivering my wordpress password to solve the Instagram problem does not seem serious. If the Newspaper has stopped being compatible with Instagram, tell me directly or give me a solution that I can prove. My version is 9.2 and you promised that it would be solved. You also do not answer my tagdiv social counter question, I’m really disappointed. If you can not solve this problem, say so and try a different plugin for the page.
We can only investigate closer if you can provide a temporary admin access to the website, cPanel may also be needed to take a look to the server settings. In some cases a security setting or firewall active on the server was causing the problem.
In theme version 9.2 there was no issue with Instagram except from a few cases when he Jetpack photon was causing the images not load when active.
Here I tested with theme version 9.2.2, everything is in order – http://prntscr.com/mtk6fs
The ID has to be correct and it should work for you as well. Let me know.
Please, I still have the same problem. The instagram element does not work anywhere on the page, or in the footer or anywhere, it is always the same error: Instagram data error: Instagram HTML data can not be retrieved, and the instagram social counter has 0 followers. I had to put an instagram pluggin that does work. The code that you provided a few months ago to change some files did not work. Could you give me a new code that I can try? I have seen that there are Newspaper clients that do work for them. It is important for me, since my page tries to be a professional medium.
Thank you
Please delete the social counter, clear all cache and add it again.
-> https://www.screencast.com/t/4vEjSocnRlc
-> https://www.screencast.com/t/QYRDrzZD
Also for footer Instagram
-> https://www.screencast.com/t/Ecfg8Wnmt2
-> https://www.screencast.com/t/r1JJMuljDJr
Also please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
