Social counter ID problem for Youtube
hallo,
I am experiecing this problem with social counter last vers (newsp 4).
The channel id added is
channel/UCp_RdsCACetSs5cuz87GPeg
but the social counter button takes me to somewhere else:
https://www.youtube.com/user/channel/UCp_RdsCACetSs5cuz87GPeg
Any idea about howto solve this?
Regards
I have another problem but related:
The link to my youtube channel is good (http://www.youtube.com/channel/buvgTDZ1Zl2sRnyEx9BeRg) but I have 0 subscribers instead of 4.
I have the same problem with Google+
Any idea ?
I have the same problem with YouTube showing 0 subscribers ) :
@Tommy
I have checked your youtube channel on Social Counter and it works fine also when I click on subscribe it takes on your youtube channel so please make sure that you add it properly(also you can check this only with Visual Composer and Social Counter active) – http://screencast.com/t/r5wF6IeTAYYT – http://screencast.com/t/ohVtfZ5YI
Please provide a link so we can take a look.
@Zba
and @skykid Please provide a link so we can take a look, also make sure that you use the latest version of the Social Counter(if you use Newspaper 6 it should be – http://screencast.com/t/iXAXhZdCKuX ). Also you can try the above suggestion.
@Alin
here is my URL : http://www.theskykid.com/
The counter links correctly to the channel , but doesn’t show subscribers count
Hallo Alin,
the ID is the same and it is what I used for Youtube field.
I tried to disable plugins but it didn’t work.
What social counter seems to uncorrecty add is the /user/ before channel/id which should not be there.
Please have a look to your email. (from: powerize@gmail.com)
Just sent link and login
Looking forware
@skykid
Your subscribers number must be visible – http://screencast.com/t/l4jEi89l Try to activate it from youtube settings – http://www.reelseo.com/hide-youtube-subscriber-count/
@sportujeme
Please make sure that you have subscribers visible like I suggested above and provide a link if you have added your youtube ID properly.
@Tommy
We will take a look and we will provide an answer as soon as possible.
I have subscribers visible. 2 weeks ago social counter was ok. I think I have upgraded plugins…
https://forum.tagdiv.com/topic/social-counter-shows-youtube-subscribers-0/
@Alin – changed the setting at Youtube , cleared the cache on the site but it still shows 0
  • This reply was modified 11 years by skykid.
Now Fixed – Thank you so much !
