I try to install a social sharing plugins () but It won setup as it suppose to be on the top of the picture (like the one you already have on the theme), for some reason the social sharing button show up bellow the picture (see: http://prntscr.com/5r28v7). Can you help me with that?
You can use shortcodes and add the plugin shortcode directly into posts’s template using the do_shortcode function. You need to edit the loop-single.php file and add it above the title like this or replace our social sharing: http://screencast.com/t/JV4sz8Lzhn
You can disable the theme’s social sharing buttons from theme panel: http://screencast.com/t/42dPYTOMC1
