Social shearing and Related Article not showing on the City News Theme i checked the settings and resaved but nothing showing.
Please make sure that you make the settings like in our documentation -> https://forum.tagdiv.com/sharing/ -> Related articles -> https://forum.tagdiv.com/related-articles/
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
All still remain the same not showing, i set as shown did what i had to do but everything stayed the same, what do i do from here?
Here is the website https://azzevo.com/ if you go to any article you would see.
Just make sure that you clear all cache after you made the changes in theme panel.
Please make sure that you do not change any files in theme files, also make sure that
If the problem is still there, please delete( delete the theme plugins too, do not override ) the current version of Newspaper that you have and download again from themefores the newspaper and reinstall it.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
