Solution for Fast Cache using the mobile theme plugin
Easier.
If you want to use caching with the mobile theme plugin. Use WPRocket plugin.
Settings http://prntscr.com/du4lvx And disable “Lazy Load” on theme panel.
More information.
I’ve been looking for options for configuring caching with the Newspaper theme.
Plugin developers proposed, it does not give the normal performance. To him must be a large number of add-ons and other “manual” changes.
At all of the sites I use a caching plugin W3TC. But on this theme there is a great (!!!) mobile theme plugin and it does not work in tandem with W3TC 🙁 When caching to the phone, on your computer to open the same type of phone.
The solution found is simple, but requires a small investment. This installation of the plugin cache WPRocket. It is a function of support for individual mobile caching pages. Screenshots of my configuration: http://prntscr.com/du4lvx And disable “Lazy Load” on theme panel.
It is thus possible to achieve a very fast performance of your site.
One of the downsides of the plugin, it is very demanding on server resources. Can not come to the weak hosting.
Sorry for my English. I use Google translate 🙂
Viewing 1 post (of 1 total)
