Some Megamenu components do not work
Hi there
The mega menu opens and lists the categories in desktop , but when I hold the mouse over the category, it does not show the subcategories and the pagination icons do not do anything when clicked. It seems that the mega menu does not load correctly and this problem appeared after the update. It is set to load optimized in the settings. bsiminzar.com
  • This topic was modified 2 years by babak.s.z.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
If the problem is still there, then please get in touch with us via email at contact@tagdiv.com and provide the following:
– admin URL and credentials
I will check and try to help you as soon as possible!
