1. turn off comment box (newsmag theme)
2. turn off Author picture in single post.
1)If you want to turn off the comment section you need to disable that option for each post page you want from here -> https://www.screencast.com/t/HkiiNuWmNwj
2)If you need to remove the image from your author box section, you need to use the code below and place it in Theme panel -> Cusotm CSS area.
.author-box-wrap img{
display:none;
Hope this helps!
sorry, I do not have a comment button on this website or any other site’s dashboard.
If you are using the Gutenberg, please check here -> https://www.screencast.com/t/unEebUm5pBua
