Some problems
1-I want to delete the writing only
2- I want to delete this
3-Change this color
  • This topic was modified 9 years by adam21s.
1. Removing the Back/Next from the smart list pagination can only be done by modifying the theme files. You can try removing the text in this file, from these locations
– https://www.screencast.com/t/WtAQrsWo1w
– https://www.screencast.com/t/m5LXRTQNow
2. The author box displayed on the post page, can be disabled in theme panel
– https://www.screencast.com/t/ffTJUg8P20X
3. If you want to set a background color for the bottom sharing, you could do that with a code like this
– https://www.screencast.com/t/CImJhWySp
The code must be entered in Theme panel->Custom Css
.td-post-sharing-bottom {
background-color: red;
