Hi everyone, I have some problems which I can’t fixed. I would be very happy if you could help me.
1.In this page the menu crashed. The only way for fixing this problem is add blog posts. On the other hand I can not fix it. Do you have ant suggestion about it?
2.As you can see in the picture, I choose “Latest” for Sort Order But the order is not correct. My latest posts are not seen. I also have same problem for other pages. Whenever I choose latest for order. I can not see all my posts.
3.My Mega menu always have this problem. Loading takes too much time! Sometimes never end! Sometimes working properly. I don’t know how to fix it.
Thank you very much for all your helps. Have a good days.
Hello !
I have inspected your website and everything seems to be in order. Please make sure to reset your website when you go mobile viewport: https://www.screencast.com/t/reAHXQi7oso ; https://www.screencast.com/t/1fzqDKsOlVC
Hello !
If we are talking about the issues presented in the first reply I have already inspected and everything seems to be working fine now. Everything works correctly.
Please make sure to clear your cache or use another browser to test.
Are there any other issues ?
