I update yesterday the version 6 from 4 and i want ur help here:
1) JS composer appears like this!? http://www.alexiptoto.com/wp-content/uploads/2015/10/js.jpg
where are the blocks???
2) There is no option on widget Titles for style 1. Only the default style is available. How can i Change it to style one please???
– Right now in all my widget titles i used white background color and when the visitor move the mouse to a post title it became white. How can i change color
Thanks!!!!
1. I cannot see you image to understand the VC issue it redirects to – http://screencast.com/t/TxjonXpF
Please make sure you update also the Visual Composer properly, deactivate and delete it from Plugins, then install it from here â http://screencast.com/t/NeIrAMKdm3
2. Unfortunately the block title style 1 that you used in previous version doesn’t exist anymore in version 6 and you have to edit each homepage blocks(or your widgets) and change the background color â http://screencast.com/t/7qRvDzjc
Newspaper 6 is a whole new theme that is released for free for all of our existing customers so an update from 4 to 6 may cause the same issues as switching to another theme (but we did try to maintain compatibility where ever possible). We tried to find the best way for the transition(the script), but some issues may appear. We are very sorry for all the problems that the update caused.
ok thanks. I know but version six is really cool
1)I want also to ask you how to delete this http://i.imgur.com/Z1IfKoq.jpg
The number of the views on the post page WITHOUD Disabling the view count!!!
I dont want my visitors to watch the post views only the admins!!!
2) Also this is a correct picture of the VC witout the modules on it !! http://i.imgur.com/n4bPFBM.jpg
I dont know why and how they dissapear. This happen only to me??
as you can see there is no edit option on the blocks!! đ
ANd i have problems with the Tags!!! No tags appear please check this
http://www.alexiptoto.com/tag/%CF%83%CF%89%CE%BA%CF%81%CE%AC%CF%84%CE%B7%CF%82/
what u advice me??
1. You can hide post views via custom css in Theme Panel > Custom Css – http://screencast.com/t/nwr7yQRBX
.td-post-views {
display: none;
2. Please make sure you select all elements from Visual Composer settings(and save) – http://screencast.com/t/CLOL9hsaZ
3. Please check the Tag template and change the module(the search module doesn’t exist in version 6) – http://screencast.com/t/Tb918utRX
Perfect!!! Amazing Support!!!
I notice yesterday two more problems… one small and one serious i think ..
1) http://i.imgur.com/2bHyW9n.jpg Please check the picture on the home page here http://www.alexiptoto.com/ and tell me how I can reduce this white gap some pixels!!!
2) I notice that the website is a bit slow after the update. I used the plugin P3 PLugin Profiler and I notice the problem here ( http://i.imgur.com/P3BiSkU.jpg ) . The MySQL Queries are more than Double after the update!!!!
– I didnt add any new plugins , actually I delete some I had
– I deactivate my most heavy plugin and still I had the same MySQL Queries.
I want to ask if there are more users like me who faced the same problem or its just me. i really would like to listen ur advice!!!
1. This gap comes from the block title, even if it is not displayed the container is still there. So you can try this custom css in Theme Panel to hide block title when it is used in Tabs element – http://screencast.com/t/zoaBg7LwVDYo
.home .td-pb-span4 .vc_tta-tabs .block-title {
display: none;
2. We did not tested P3 PLugin Profiler to see how it works, but what I can see from your screenshot you use the same number of plugins(7) even if they are different and the Contact Form 7 plugin has big impact on your site now – http://screencast.com/t/tCmE7SjhbG
Great! Thanks for the help!
I try to activate also the wp super cache following your instructions bad in my home page after activating the plugin is like this http://i.imgur.com/7fQk3Ey.jpg
The rest website looks fine. Is it easy to fix it somehow??? Any other user face same problem maybe???
THanks!!!
Please make sure that the plugin was installed properly and all the files were uploaded properly. You can try to connect via FTP delete wp-super-cache folder, then try to upload it again.
