Hi , I´m having some issues with Woo commerce + Newspaper theme:
(Pictures: https://imgur.com/a/AOHUpvG)
1. Woo Menu Favorites is not counting items added to /Wishlist page (TI WooCommerce Wishlist plugin used).
Short code used inside column text element: [ti_wishlistsview].
Is there a way for this to work? Or how can I use the Woo Menu Favourites in a native way only using Tag Div Shop? Is there documentation on how to use this block?
2. Zoom not working on product images. The zoom button is present, but it only shows a normal slideshow gallery once pressed. Tried all common zoom plugins and none worked, it seems the theme is not compatible with them.
I know there´s a code floating around the forum regarding zoom. Is there a way to solve this without editing functions.php file? In case it isn´t, can you point me step by step how to edit this? I´m new to coding and don´t want to break my site.
3. Search results are eliminated once I change in Theme Panel the search template from the default – Theme Template – to a Cloud Library Woo search specific template. Curiously enough, the woo posts block still shows the correct results in composer editing mode, but not outside of it.
I´m using Relevanssi plugin, but this happens with it deactivated too, and their documentation says they should not have Woo commerce problems anymore since lasts updates.
Many thanks!
Jonatan
Hello Jonatan!
1. Yes. You should use the tagdiv shop plugin and the cloud templates at https://prnt.sc/Kci–v0QipZX for shop. Here is the documentation for that element that you asked about: https://forum.tagdiv.com/woocommerce-happy-add-favorites/
2. When you hover over the product image, the product will zoom in, and when you click on that magnifying glass, it will open a modal with that image. You do not need a plugin for that. This is by default in our theme.
While you use cloud templates, you don’t need to change the code in the theme. You can simply edit the product page with the tagdiv Composer: https://prnt.sc/x9T7AuFoP_Sp
3. There should be a conflict with some plugins. Also, delete all the cache and try again.
I’m sorry, but we cannot provide support for untested plugins.
1. I follow the process but when the counter is at zero, it still shows the product on the favourites page. As per documentation it seems that I´m only ordering by favourites, but not telling the block that if there are no favourites it should show nothing at all. Any way to force it to don’t show anything when the counter is at zero? Or maybe it isn’t working as expected?
2. It works now that I used bigger images. With smaller ones it has no effect.
3. Ok, probably plugin conflict.
Hello Jonatan!
1. Can you please provide a video with the issue? So, I can check if there is a problem or not.
2. I’m glad.
3. Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
