Some question about speed
From this site http://tools.pingdom.com/fpt/#!/cN4TO2/http://ISerres.gr
I figure that main.css?ver=4.5d loading time is very bad
Is there any solution for this?
I use your speedbooster and I set it in the same way of your tutorial
Also, my score from here https://developers.google.com/speed/pagespeed/insights/?url=iserres.gr&tab=desktop is very good, but the loading time of the page is not good. Why this happened? I know that the response time from my server probably is one of the problems but I think this is not the only one
What’s your opininion? Do u suggest any fix for all these?
Thank you
Please can you try to disable all plugins. Also i see that you css is minimized and the name of it is main.css and our is style.css.
For good speed we recommend to have a good server and also to use a cdn for images.
Also here are some speed discussion if you want to read some tips: https://forum.tagdiv.com/topic/theme-speed/#post-900
Hope this help!
