Here the Some Recommendation for Mobile device:
#Firstly, Move menu on left to right. It helps to user to use the menu. The user easily uses the menu (Try yourself). Like this:
#Secondly, Disable the popup search bar. Make search bar like this:
#Thirdly, Make default social Floating sharing like this:
Check this site on the mobile: https://www.theodysseyonline.com/
It makes more user-friendly & Google friendly.
Sorry but we cannot offer customization services as mentioned by the support policy: https://forum.tagdiv.com/support-policy-2/
The theme has no settings for this requirement and we do not have a customization department to tackle such tasks. We recommend hiring a freelancer to help with the customization needed.
