some rtl issue and fonts
first thing I need change full website font for custom font I make it in css but it change some places only
and see shots below please cos I’m web host company and I will work with your templates and need you give me a hand to buy more so I need to fix this asap
1 – I need to change footer color to black.
2 – big slide need change thumbnails position to left screen shot below
http://2up.pw/uploads/1426157553831.jpg
3 – any widget header aligned to the left ?
4 – I need to make custom ads 2 and 3 at web site sides how to make it what is the ads short code and how to make body fixed cos its so wide so that side ads cover logo check this
http://2up.pw/uploads/1426157697241.jpg
and tell me how to hide it from mobile and tablets
5- rtl issue in menu please check this
http://2up.pw/uploads/1426157777891.jpg
need to fix it and tell me how to change its fonts
6- blocks font how to change it please cos I change it in menu and other places don’t know how to fix it
check below shot
http://2up.pw/uploads/1426158121462.jpg
please tell me how to fix this and you should make every sing trl so that we not face problems any more
1. You can change footer background from Theme Panel > Theme Colors: http://screencast.com/t/2yBVGWU0Q
2. Please follow this topic: https://forum.tagdiv.com/topic/big-slide-left-to-right-fonts-arabic/
3-4 Provide a link and more details.
5. Please try this custom css in Theme Panel > Custom Css: http://screencast.com/t/pAFd6TGGvSvb
.block-mega-child-cats{
text-align:left;
.block-mega-child-cats a{
padding: 6px 0px 6px 21px;
.td_block_mega_menu .td-ajax-next-page{
left: auto;
right: 270px;
background-position: -20px -1948px;
.td_block_mega_menu .td_ajax-prev-page{
left: auto;
right: 240px;
background-position: -20px -1990px;
You can change mega menu fonts from Theme Panel > Custom Typography: http://screencast.com/t/kiw8KbAEqo2
6. I’m not sure what you mean. If you want to change block title an excerpt fonts you can do this from Theme Panel > Custom Typography: http://screencast.com/t/QcbCK4H4EXoK – http://screencast.com/t/1bKn85xOlz
Please search the forum for suggestion and fixes for the issue you may encounter with this and you should also consider that unfortunately we recently have decided that starting with the next theme update we will not include rtl support within the theme. You can still use the theme as it is but unfortunately you cannot updated it as you will lose the rtl support or you can update it and make yourself the necessary adjustments needed.
