Hello everyone,
I bought the newspaper theme for my blog. Now I want to custom the module flex 2 on my home page. I want to display the image in full width (no problem for that) but i want align the meta infos with other modules under the module flex 2 (I set 1200px for other module) and if i set padding or margin there is a problem on other screen…. How i can do that ? The meta infos on module flex 2 must be align with other modules on any screen.
To be clear you can check my website to understand my problem : http://image.noelshack.com/fichiers/2018/50/3/1544602867-fireshot-capture-19-je-suis-cinevore-i-un-blog-parmi-tant-d-autr-https-www-jesuiscinevore-fr.png
If I understand correctly you want to align the meta info from flex in line with the rest of the blocks, if is so please set the meta info width 1068 and meta info margin auto
https://www.screencast.com/t/VMU8i9FInoE
