Thanks Catalin, the code works. I have another question, I have a category called “Games” and want to hide the date of the posts in that category in the search results. I can now hide the date of the posts of a category, but look for that post in the search, always displays the date.
As hidden the date of that category of the search results?
Hello diablo7,
As a basic solution in this regard would be to change the module mx2 because this type of module is used in Live Search feature. Please notice that is not a simple task and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry! In the future, please do not make more topics about the same problem. Please make a single topic with your problem and we will try to answer you as soon as possible.
