sort post by most commented does't work!
in tab i sort post by most commented and it’s not work! why? i have just 2 comments, but it isn’t show up:(
Please provide the url so i can take a look.
Thank you, Emil G.
http://www.crnjaci.com
in tab, name: KOMENTARI (most commented)
thank you.
I have tested this using the latest theme version(4.6) and found no issue with the comment sort order in tabs, I have also tested this into the sidebar and still haven’t found no issues with it.
Please try to disable all plugins and make sure you empty cache then check again.
