Sort posts in block 11
Can i reverse latest posts in block 11? Form ASC to DESC or vice versa?
Thank you
Did you have checked the Block Settings from here? -> https://www.screencast.com/t/rcVqVebfUiO
Not what I want 🙂
So i choose oldest posts and now I want to reorder posts from neweset to oldest
https://prnt.sc/m2k705
can this be done?
Hi gregy1403,
Look at this -> https://www.screencast.com/t/1XiiC6tmK if you want to order the posts from newest to oldest.
No matter what i choose (Oldest or latest), dates are not sorted. Let me write it down, that we use “Future posts” where we are allowed to post future posts. Makes sense when you see that we use it for events 🙂 No past posts..
https://prnt.sc/m2lgww
Please remove all of the untested plugins, clear all the caches and check the results. If you will sort your posts to be, by latest, you will have to have all the newest posts in front of oldest posts. If the problem persists, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer to this functionality.
I tested it with all plugins OFF, no luck. Went further and made some “research”. I copied a block 11 which is already sorting by date, but only specific category. Duplicated block worked, but when i changed to “All categories” it stopped sorting .. oldest posts were first. Went back and choosed specific category – working again.
Could be bug when displaying “all categories”?
thank you
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page.
