Sorting posts problem
Sorting not working on center and left blocks. No matter what I try, it’s pulling up old posts.
Sort by “Latest” doesn’t work. Sort by “Featured” doesn’t work either (shows a blank post).
https://www.themusicvoid.com/
Thanks in advance.
Robert
Hello Robert,
Please provide some screenshots with your settings. Also, make sure that your changes are saved.
Problem solved! It was caused by the “Offset Posts” setting.
I’m glad that you found the settings.
