Hi, i’m trying to do a fast demo with “Sound Radar”.
The problem is that in my demo the 3 articles do not are full width.
Please check: https://www.dropbox.com/s/am6o0sv7h673adx/sound-container.png
What is the correct setting to have a layout as the demo (https://demo.tagdiv.com/newspaper_sound_radar/).
Could i need to set this panel? How in detail?
https://www.dropbox.com/s/186pm1ef46kltei/sound-panel.png
Really thanks.
Hello 22p,
You should use the Big Grid 3 full width like in our demo from here -> https://www.screencast.com/t/VRprRdq2
Hi 22p,
You simply add the Big Grid Full 3 and it will be set up in full-width by default, as you can see here -> https://www.screencast.com/t/NNdkN5caDBU Also, if you are using the Background, notice that the theme will be automatically switched to the boxed mode and the result should look like this -> https://www.screencast.com/t/vnZ31TI7
> but these elements are available only if the page is created with TD Composer
Sorry but i do not understand.
So the home page of Sound Radar was not build with Visual Composer but also not with TD Composer: https://www.dropbox.com/s/2f2darp7qv75kkd/sound-panel-01.png
Anyway i can not use TD Composer.
So i set this with Visual Composer (full width – no paddings row) but i have too much height in the 3 box:
https://www.dropbox.com/s/at2yri55utancxy/sound-panel-02.png
How can i have the same height of this demo?
Hello 22p,
Try to the code from here -> https://pastebin.com/qWKVvJ13 and place it in your homepage text like this -> https://www.screencast.com/t/LUIyKBk0mCO This is the homepage for that demo.
Hope this helps!
Sorry but this do not work as the demo.
It’s the same situation that i see when i import demo content.
See: https://www.dropbox.com/s/n1uzuyex08czvrk/sound-panel-03.png
Any ideas?
Hello 22p,
The easiest way, in this case, is to install the sound radar demo and check the homepage to see how it’s made. Also, ensure that you are not using the background image to your website because if you are using something like this, the theme will be automatically boxed.
Hi Catalin, i installed the sound radar demo for 2 times but never change.
And sure in do not use background image.
Please send us an email at contact@tagdiv.com and provide admin login information. We will take look. Also include a link to this topic in the email.
