We are not seeing the author or source in the top of the article. Site is manufacturing.international working with newspaper 12 theme.
example page is here of the issue
Feedzy said this:
“Feedzy is designed to be compatible with a wide range of themes and plugins, including popular ones like Newspaper 12. However, conflicts can still occur due to the specific configurations or customizations in place. As you can see in my screenshot, the Newspaper 12 theme is enabled, and the author is visible correctly on the page. The problem occurs when we enable the tagDiv Cloud Library plugin. We recommend that you please contact the theme author and ask them to check why it is happening. Since they developed the theme, they are well-equipped to guide you on this matter.”
Their screen shot
https://vertis.d.pr/i/cRiDxf
My guess is their is another way to fix this besides disabling the tagDiv Cloud Library. I think that may have other ramificaitions
Please help
Mike
When we bring feeds into WordPress, using different method, there has to be an author/contibutor in the system for the feed to align with. Meaning, if author is James Smith, there must be a James Smith user setup for the story to align with.
(I don’t work here.)
