Spacing between images in blocks
Hi there!
I just installed your theme and so far I looove it!!! Thanks! however on the homepage there is a lot of spacing between blocks and between the images using the Big grid full 8, on your demo it shows very little space between images but I can’t get it to narrow… how do I do it?
Hello danild,
If you want to reduce these spaces, you should use a bit of CSS code. Try the code below and place it in Theme panel->Cusotm CSS area.
The code is ->
.td-big-grids-fl.td-big-grids-margin .td-big-grid-post{
border-width: 0 2px;
