Hello All,
The domain name is – https://sustainabilitynext.in
The posts are looking nice on the homepage with nice spacing between the post, but the same posts on mobile preview does not have any spacing between them. Both the screen shots are attached. Please guide me how to get the spacing between them on mobile preview.
Try to regenerate your thumbnails using a plugin. Check this: https://forum.tagdiv.com/using-the-theme-with-existing-content/
Let me know the results!
Thanks, it worked except in most of the places, except in one or two places, where the thumbnails did not get changed.
Thanks, the plugin has done its work and it has taken some time. All the thumbnails are now set. The only problem I observed that, the banner which is on top is also resized
Please provide more information about that banner and point me directly to the issue, screenshots or a video.
Thanks, I could achieve displaying the buttons after following your instrctions. But there is a small problem. The buttons on mobile preview is top aligned. But I need it centre align. In the left panel I have given it as centre, but still the button shows as top aligned. Can you please help me to make it centre aligned.
Please check the answer from your own topic here: https://forum.tagdiv.com/topic/arrangement-of-buttons/#post-432520
