Spacing issue of Post Title on Home Page
Hi there,
1. ) I needed to remove the author name and date below the post title on the home page as well as on the Single post page. I applied the following code which did remove it from the home page sections, but however the first post title has slipped down from its original position. Kindly see screenshot.
Code which was applied – .home .td-module-meta-info { display: none !important; }
Screenshot – https://www.awesomescreenshot.com/image/2854141/1c3f44969419c9221d216f34f13f299d
Also the code mentioned above did not remove the required elements from the single posts page.
Screenshot – https://www.awesomescreenshot.com/image/2854149/7121a51f77c8838d6d5689357b650f26
2. Can the category mentioned below each thumbnail be removed? kindly check screenshot.
https://www.awesomescreenshot.com/image/2854157/d07f47840b8e5f824fbc57b5aa24e39d
Thanks,
Prasenjit.
1. There is no need for code to be used for removing the author name and date, either on the post pages, or pages. There are options in the theme panel, this is for the post page
– https://www.screencast.com/t/pqjEK1x1n21
And this option is for modules and blocks
– https://www.screencast.com/t/q5QR68ozCf
2. The category tag can be removed in the theme panel, for each module
– https://forum.tagdiv.com/category-tag-on-modulesblocks/
