Hello please check out the following dropbox url for a problem that exists on spacing between the main header menu and the main content. I did not touch anything i have just used the Beauty Blog theme and then i changed then i changed the header style to 10. I know programming i can touch the css if i have to…waiting your response thank you.
https://www.dropbox.com/s/bieoo6q6uw5iug4/download1.jpeg?dl=0
I cannot replicate this problem you re having on my end. It would be helpful if you could provide a link to your website so we can inspect it and see the problem. You could use your browser inspector tool to see why this is happening – https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/ Also make sure you have updates all the required plugins to the latest version.
