Specific color for heading and excerpt inside a 'block' of category
Is there a way to have specific color for text on (heading and excerpt/body) inside a block of category on homepage of http://demo.tagdiv.com/newspaper_tech/
Regards.
Hello rtofficial,
If you want to have a specific color, please notice that you should use a bit of CSS code to do that, like below code. -> http://screencast.com/t/ebMG483Utq If you want to have a specific color according to the category, please notice that you will have to edit the code in order to achieve this and please notice that is not a simple task and it required additional customization and we cannot provide custom work at the moment, sorry!
The code is ->
.td-module-title a{
color:green!important;
.td-excerpt{
color:red;
If is not what you mean, please provide more details so I will be able to provide a more accurate response.
