Hi there, I am hoping you can help explain something here for me specifically on posts and a post template.
– So I would like to create a template for the content of a post per category. but focusing on the body text and body layout specifically like so: https://share.getcloudapp.com/P8ukE9n6
– Also this is a follow up video here: https://share.getcloudapp.com/4gu1yl0P
– So as you can see I want to make sure a initial template is launched on the post itself and then the author or editor of the post can tweak its copy and content as they see fit so to speak.
Is this possible or am I missing something obvious as I am not too familiar with the tagdiv editor and blocks actually. I do not want to have to build a post from scratch in terms of the various elements it needs each time around if that makes sense.
Hopefully you can help here with this.
Thanks,
James
Hello !
You can set post template only on one category as you can see here:https://www.screencast.com/t/cuqa9Rvf
You can set a global template in order for that to have a template but that can be edited only from Theme Panel – Cloud library. And you cannot adjust 1 template for more posts only if you duplicate it for each post.
