Speed booster and akismet
Yours speed booster does don’t want to work with Akismet plugin (default wordpress one):
v4.5 - Disabled - incompatible plugin detected: akismet/akismet.php
Please, update it so it will work with it, otherwise, whats a point of having this booster plugin at all?
Note that the Speed Booster plugin disable itself when an incompatible plugin it’s installed. We added this measure to avoid conflicts with the plugins that won’t allow to move their CSS/js resources at page bottom. To keep it always activated comment or delete the indicated lines from td-speed-booster.php: http://screencast.com/t/RZLIOPUNdqh You can check this topic for more information about speed booster usage: https://forum.tagdiv.com/topic/speed-booster-questions/
Hope this help.
