Speed Booster and AMP Plugins
I am using newspaper theme, whenever i activate AMP Plugin, system disable speed booster.
When i deactivate AMP Plugin speed booster works fine.
Please any solution?
Seems that was overlooked, I will add it on the list. The fix is to edit the speed booster plugin and add this line of code in the allowed plugins list
http://prntscr.com/niox86
'amp/amp.php'
Sorry for the inconvenience. Let us know if you have more questions.
Hi Simion, how can I confirm if the plugin is active on my site and not deactivated by another plugin?
Found it in System Status.
Even the speed booster gets disabled for Akismet. What line of code I have to code to make it compatible.
@mimicreature That will happen, akismet isn’t in the plugin list. You could add it like this in the booster plugin code – http://prntscr.com/nkxv8b
'akismet/akismet.php'
