In my 7.0.1 Newspaper system status I have got this message:
Speed Booster v4.4 – Disabled – incompatible plugin detected: all-in-one-wp-security-and-firewall/wp-security.php
Is there a way I can enable Speed Booster with using the wp-security plugin?
And which security/firewall plugin do you recommend which is compatible with this theme?
Hello jansena,
Please notice that the speed booster is an optional plugin and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that they add many plugins and some of the them are not written fine so the developer took this decision. If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
