Hi there,
For the past few months, I am using AMP plugin called Accelerated Mobile Pages for my site. But recently after I activated the Newspaper theme together with the Speed Booster plugin, I received below error.
Speed Booster v4.5 – Disabled – incompatible plugin detected: accelerated-mobile-pages/accelerated-moblie-pages.php (yellow indicator).
Could anyone help me how to fix this?
Thank you,
Hafiz Rahim
Hello hafizrahim,
The speed booster is an optional plugin, and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2, and if you use other plugins, it will be automatically disabled. A lot of people install the plugin without knowing what it does, and after that, they add many plugins and some of them are not written fine, so the developer took this decision.
If you always want to enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
