I have installed latest version of newsmag theme, but Theme says that “Speed Booster” isn’t compatible with plugins as akismet, wp-cron-missed-schedule etc.
I think there is a bug/error, because I don’t guess that a plugin as “Speed Booster” is conflicting with a so important plugin as akismet.
Thank you for support!
You can add support for akismet if you use it (many of us don’t, having removed comments from our sites to avoid spam/bots); simply read the docs for the *optional* speedbooster plugin *if* you want to use it.
You can also do what I did, which is simply use the “scripts to footer” plugin which kinda does the same thing, without any drama.
