Hello Twolle,
Our Speed Booster plugin has been designed to work properly with some tested plugins, as you can see in this screenshot -> http://screencast.com/t/ojSRErqBEI8 Please note that the Speed Booster plugin disable itself when an incompatible plugin it’s installed. We added this measure to avoid conflicts with the plugins that won’t allow moving their CSS/js resources at page bottom. To keep it always activated comment or delete the indicated lines from td-speed-booster.php: http://screencast.com/t/RZLIOPUNdqh You can check this topic for more information about speed booster usage: https://forum.tagdiv.com/topic/speed-booster-questions/
Thank you for the message!
