When i check System Status of theme, it shows me that Speed Booster: v4.4 – Disabled – incompatible plugin detected: vaultpress/vaultpress.php
Can you please tell me a workaround to make the speed booster plugin run with Vaultpress?
Using this plugin is very important for me and i can’t skip it.
Plugin link – https://wordpress.org/plugins/vaultpress/
Hello all,
The speed booster is an optional plugin and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that they add many plugins and some of the them are not written fine so the developer took this decision. If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
Thank you for your message!
