The Speedbooster plugin works with CDN. We use it on our demo with Cloudflare CDN and it works as expected: http://demo.tagdiv.com/newspaper/
Unfortunately the fact that it does not work on your end could be number of things. It depends on how you set up your CDN server. Please use another configuration and check speedbooster again.
If you say it works then it is probably something on my end (cdn configuration). I will look into it and report here later when I find out more. (Even now I think that I know what is the problem – probably the part where my cdn configuration ignores original headers. I’ll set it up not to ignore it) 🙂
