Any developments with speed booster and revolution slider? The plugin
As I can see http://demo.tagdiv.com/newspaper/ slider works and it has speed booster plugin activated. Am I missing something?
The plugin gives the following error when I activate speed booster plugin:
You have some jquery.js library include that comes after the revolution files js include.
This includes make eliminates the revolution slider libraries, and make it not work.
To fix it you can:
1. In the Slider Settings -> Troubleshooting set option: Put JS Includes To Body option to true.
2. Find the double jquery.js include and remove it.
Maybe adding revolution slider js declaration after newspaper js declerations before </body> would fix it?
