Speed Booster Problem
Hi speedbooster works great in speeding up my site however it sometimes causes my main menu background to turn black from its usual white when loading a page momentarily. I’m not sure if it’s the default #222222 showing. It looks like a total invert of the colours as the usually black text turns white when the main menu background turns black.
I hope this makes sense. http://www.learnbeatmaking.com
I’ve semi solved the problem by changing the css file to load it white instead. I lose the text in the header momentarily however but I am ok with this I suppose. Thank you.
Glad that your solved this!
Unfortunately is usually happens because of the speed booster plugin which move the css and js at the bottom of the page structure so that the page will load faster, this is why the theme’s color appears first then changes, because of the cascading property of css. To avoid this you could try to make the changes directly into theme’s style file.
