Hi, i have a problem with speed booster after update
v4.1 – Disabled – incompatible plugin detected: CDN-Linker-master/wp-cdn-linker.php (it is written in Newsmag system status)
also i have incompatibles with other plugins,
how to solve this problem?
This topic was modified 11 years by
boyz.
From this version speed booster plugin is automatically disabled as it is tested and it works fine with some recommended plugins. Many people install the plugin without knowing what it does and after that they add 100 plugins and some of the plugins are not written ok(some of the plugins do not respect the google pagespeed recommendations of punting javascript at the end of the page).
If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
Understand your discouraging too many plugins. I am myself in the process of removing some system demanding ones such as NextGen Gallery. However I have 10 your system objects to that my site currently depends on until I can adjust the various many posts.
I can’t see me removing Disqus… It also objects to your “tagDiv Visual Composer Shim”…
Can you explain more what your hoping to do?
Hi ShowbizCool,
Please see Radu’s post for more details on this here: https://forum.tagdiv.com/topic/speedbooster-not-moving-all-the-files-to-the-footer/#post-55023
The tagDiv Visual Composer Shim (an experimental plugin in beta version) or Disqus can be added to that list like this: http://screencast.com/t/r54qKzKuQiG just add them using this code:
'disqus-comment-system/disqus.php'
'td-visual-composer-shim/td-visual-composer-shim.php'
Hi Lucian
After the latest update 2.3.1 this solution to allowing Disqus seems not to be working.
I have several attempts and I keep crashing the site. Can you re-check this?
PS With out adjusting the Speed Booster php file I am getting:-
v4.2 – Disabled – incompatible plugin detected: disqus-conditional-load/disqus-conditional-load.php
Be careful if you are using bbPress or buddypress, that you will mess up your styling with speed booster enabled. I have stopped using even with commenting the code out it still mess up the tabs in bbPress and buddypress. If it was fixed for the styling, then I would use speed booster but I don’t even see a difference in site loading either it installed or not.
I guess not too many people are using buddypress to even notice the tabs change. Tabs go fat after speed booster installed but uninstalled the tabs look normal. They also go from hover showing black to grey and the number status on tabs go from round to stop sign shape. So this is why I stopped using speed booster. This has been since I bought the theme in July.
doucare1971.
Hi @ShowbizCool
I’ve test this on my side and the plugin works fine, please make sure that you add the line as it’s indicated here: http://screencast.com/t/5Ke04QmmL9b clear all caches and test again.
Let us know how it goes.
