How do I fix this? Isn’t it a bit ridiculous that speed booster doesn’t work with so many very popular and very necessary plugins?
Hello lifemathmoney,
The speed booster is an optional plugin and it is tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that, they add many plugins and some of them are not written fine so the developer took this decision. If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
Thank you for your message!
