Speed Booster v4.9 – Disabled – incompatible plugin detected: Ultimate-Premium
I’m seeing this in system status. Can you guys help me address is or should I contact the plugin owner?
Speed Booster v4.9 – Disabled – incompatible plugin detected: Ultimate-Premium-Plugin/usm_premium_icons.php
http://interestinganswers.com
See the docs here for using the optional speed booster plugin; most plugins will NOT work with it unless you expressly add the plugin to the move list. The booster plugin works by moving and optimizing plugins when they load; but if a plugin doesn’t work that way, booster has to be disabled to avoid a conflict.
The docs here describe a method to add the plugin you’re using to its internal list. 🙂
(I don’t work here; just food for thought)
Ahhh. Thanks.
