Speed Optimization
Hi which speed Optimization plugin you suggest for newspaper. My website is pluscreen.com and I want to optimize my all issue that is showing in Google pagespeed insights. The plugins that I am using now is WP fast cache, auto optimize and litespeed cache.
I just checked your website and I see that you have quite good results -> https://i.imgur.com/AWb7vWl.png -> https://i.imgur.com/fkjQWus.png
What I can suggest is to add for this image and height and width -> https://i.imgur.com/m4a3ODp.pngthis should reduce the CLS.
Also if you want you can check our CSS Analyzer too -> https://www.youtube.com/watch?v=tnkVapqhIHc
I hope this will help you!
Thanks for your precious time I hope everything is going right.
Here I am facing light house issue that I want to resolve in mobile version.
Did you solve your issue? What did you tried for solving this? Where you test your website, you can find some help regarding to every issue for page speed.
Yes I solve some of my issues & still making it better. To solve my issue i try different plugin now I am using autoaptimize, WP fast cache and ewww image optimize plugin. And I test my website on Google page speed test. Now I am getting lighthouse error to display font in mobile version. And DMCA Banner image (height weight issue)
Please make sure that you have enabled the proper thumbs with these sizes in order to show the featured images properly, check this: https://www.screencast.com/t/N18dR3qZrh
After activating the thumbnail sizes you need to regenerate your thumbnails using a plugin. Check this: https://forum.tagdiv.com/using-the-theme-with-existing-content/
Check these guides, maybe it could help you:
– https://developers.google.com/web/tools/lighthouse/
– https://www.sqlpac.com/en/documents/google-pagespeeds-lighthouse-6-new-features-lcp-cls.html
– https://web.dev/lighthouse-whats-new-6.0/
