Hi, what is this font used for and how can I remove it?
https://example.com/wp-content/plugins/td-composer/mobile/images/icons/mobile-theme.woff?8
It slows down our site on load.
Hello !
That is the main font used by Newspaper Theme. You can change it by going into Mobile Theme – Theme fonts: https://www.screencast.com/t/JZh0JHO4us
Hello Vlad,
are you sure that this is the main font? When I open this font in a woff viewer, I see only social icons (https://www.screencast.com/t/jKAN6PNM)
If it really only contains social icons, how can I delay the load or lazy load the file? (Social Icons are not visible on initial mobile screen)
Hello !
Please provide a link to your website in order to inspect. You can try and remove the file if you are certain that the icons wich the font contains are no longer needed. Just make sure that you create a backup first.
That file is loaded from the stylesheet and the font is loaded by the browsers after the stylesheet loads.
I hope this was helpfull !
