Hi!
The problem with the site work for the ssl protocol. It remains mixed content and problems with CSS styles.
I enlisted the help of web hosting provider with this issue.
His answer: Sorry, but the problem with the logo, styles and other things there for the reason that the database of your site URL c explicitly using the HTTP defined in JSON format, which is so easy to edit can not be, because it becomes invalid after such changes. You need to refer to your themes developer to solve the problem.
It’s not an issue with the theme, I changed my site over to SSL during the week and it all works fine. Did you do a search and replace of all the old http to the new https?
Follow the steps in this guide, it’s one of the best I have seen https://www.keycdn.com/blog/http-to-https/
Make sure you have cleared all web, CDN and browser caches as well.
