Hi, i have install in my domain SSL…i have also add to wp-config.php “string” to force https for admin.
Now if i go to the admin panel google chrome say me “https secure site”…while if i go to the site chrome say me that connection maybe not secure…and https is not green with “https secure site”.
I tryed to deactivate “super cache” plugin….and also to install “wp force SSL” plugin…but nothing…not change.
Can you help me please?
Tnx a lot
p.s.
my site is: https://www.falcri-is.com/
I cannot see any not secure messages on your site. It seems to be properly set to https:
https://www.screencast.com/t/6Cqb1swhgBAw
However there are a few ssl test sites you can try to run and see what issues come up such as:
https://www.ssllabs.com/ssltest/analyze.html?d=www.falcri-is.com
or https://www.htbridge.com/ssl/
Also remember you need to do search/replace in your mysql dbase for all instances of images inserted into posts which load via http, and updated any references to logo, icon, sidebar elements, etc. in the theme panel. Some folks forget to update the RSS feed link if entered manually, etc. 🙂
Hi, tnx a lot for help.
Only strange is that in wp-admin string “secure” is displayed…while in the site not.
SEE VIDEO http://screencast-o-matic.com/watch/cbfhog6PGW
Have you any idea?
So for SSL security test i will ask to my hosting to controll it.
Well, you still need to search/replace every http/yoursite item in your post meta with https/yoursite, and check anything entered into theme panel boxes as http like logo, RSS feed, favicon, etc. — no plugin can fix any of that for you.
Plenty of tutorials online on how to do the big conversion of wordpress site from http to https 🙂
(( I don’t work here. ))
Hello ferithon,
Please keep in mind that problem is not related to our theme, sorry! As you can know, every theme can be switched to the SSL mode and here it really depends on how well you set this. Please follow the next useful tutorials and try to setup properly the SSL connection.
Please use these guides:
http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
https://css-tricks.com/moving-to-https-on-wordpress/
https://yoast.com/dev-blog/move-website-https-ssl/
