SSL scripts problem.
Hi Team,
We just installed a SSL certificate on our website http://www.gadgetbridge.com
While it shows the certificate has been installed properly.
There is a problem with the newspaper scripts etc.
On checking further, we found that the website contains mixed contains i.e initial HTML is loaded over a secure HTTPS connection, but other resources such as images, videos, style sheets, scripts are loaded over an insecure HTTP connection. Please use the below URL to find the mixed contents on the website.
https://www.whynopadlock.com/results/d79f0131-7ef3-47c4-a0e4-8af43ef83992
Please help in correcting any or all scripts that use HTTP to HTTPS, this will help with displaying images and its contents correctly.
because of which we are not getting the padlock on the website. Please help.
Useful to set site url as https in the wp admin, or better yet add fullurl path with https to wp-config.php
You will also need to search replace any image placements inside posts via phpmyadmin.
Also update logo and any other icon paths in theme panel.
Both your mixed content issue seem to be images so you might want to have a look at your theme panel and remove any image that was added before the ssl implementation. They will not change to https automatically. Check the backgrounds for the mobile search and menu as these are the most overlooked ones. Please also check the theme background and logos for header, mobile or footer.
