Sticky column does not work with auto loading of articles
If the seconds article loads, the newly generated sticky column doesn’t get sticky.
Sorry but at the moment there cannot be any sticky sidebar while infinite scrolling.
But that’s weird. The first post automatically has stick.
If you are using the infinite scroll, the sticky sidebar will work only for the firs post, after is loading the second post the sidebar is no longer sticky, is possible that in coming updates this option to be implemented in our theme.
Hey,
Thanks for your reply, it may looks a little weird that the first row had a sticky column and the infinite loaded don’t. The infinite loaded posts should be the same as the first post, right?
Unfortunately this option is not working for the moment with infinite loaded, this will be treated/fix for the coming updates.
