Sticky Offset Not Working in TagDiv Builder (Header Overlapping Issue)
Hi everyone,
I’m currently using the Newspaper theme and building my single post layout with TagDiv Composer. I’m having an issue with the sticky column (Table of Contents).
The sticky function is working, but the “Sticky Offset” does not seem to apply correctly.
* I set Sticky Offset to 120px
* The column becomes sticky when scrolling
* However, the fixed header overlaps the top part of the sticky content
But nothing seems to fix it.
Has anyone experienced this issue before?
Is there a proper way to make Sticky Offset work with a fixed header in TagDiv Builder?
Thanks in advance!
In this case, you’ll need to adjust the offset for the sticky sidebar so that it appears correctly below the sticky menu. For example, if the sticky header has a height of 120px, then the sticky sidebar should have an offset of at least 120px as well.
This ensures the sidebar doesn’t overlap with the header and stays properly positioned.
https://prnt.sc/OGdiDbI-ki4y
