Sticky Sidebar Not Moving With Auto-loading Posts
The sidebar is not scrolling with the second, third, or fourth posts that are auto-loading. How can I fix this?
Video: http://sc.com.ly/show/n6grb1j8wJSWD5cFlOKUEuRmMqBpfdit
Unfortunately, if you have the option infinite load activate the sticky sidebar works only for the first post, then for the rest post, the sticky sidebar will not work.
Hi Anamaria,
When will this get fixed? A sidebar that doesn’t stick will cause loss in ad revenue for many of us.
It’s been a loooooooong time 🙂
It was implemented in this manner, and therefore it is not a problem. I added it to our list of new features as a request.
Hi, why are there multiple sidebars on the same page that is displaying multiple posts? Is it not possible to display only ONE sidebar that continuously scrolls with multiple posts instead of the same sidebar appearing multiple times (one for each new post)?
Please see screen: https://imgur.com/a/LzT22Tu
I think the ‘problem’ is that the implementation is not very good in that case. It doesn’t perform as most would expect it to, and therefore it’s not very useful to a lot of us. Maybe it needs a re-think on how it should be implemented.
It is in the list of requests, and one of the developers will look into it.
